H.FERGUSON MODEL #?
Jerry Doyon
08-24-2004 07:03:04
I have just purchased a H.Ferguson tractor. From the ID plate above the steering wheel I found the serial number TO-47854. And on the engine block I found what appears to be a casting number CWC L313. There also seems to be a plate on the left side of the block that is unreadable. From what I have found it The serial number is from 1951, but it can be either a TO20 or a TO30? How else can I determine what I have?
Jeff-oh
08-25-2004 06:00:34
 Re: H.FERGUSON MODEL #? in reply to Jerry Doyon, 08-24-2004 07:03:04
Also,
If engine has a Z-120 on left side near bottom it is a TO-20 and if Z-129 then TO-30.
Mr Chapp
08-24-2004 09:49:50
Jerry... If I"m reading right, it should be a to20. Wish any of the engine plate were legible, It would sure help. Someone will be able to help more I"m sure. Good luck, have fun!!
John (UK)
08-24-2004 14:04:22
 Re: H.FERGUSON MODEL #? in reply to Mr Chapp, 08-24-2004 09:49:50
If the engine has an external oil filter on left side of engine its a TO30, if it has large round plate on the oil pan the oil filter is in there and it will be a TO20
Jerry Doyon
08-26-2004 07:13:33
 Re: H.FERGUSON MODEL #? in reply to John (UK), 08-24-2004 14:04:22
Thanks guys! From the info. given by Jeff-oh, John(UK) and a old tractor catalog, I was able to determine that my tractor is actually a TO-30. It has the external oil filter and another number cast on the block that started with Z129-XXXX. Now I have ordered service and parts manuals.
thanks again!
