Govenor and Timing cover
Bill In Markham
09-26-2004 03:59:28
Has anyone run an oil line to the timing cover to supply more oil to the chain etc. and if so where did you tap it into, I was told this would help the existing splash method..... cheers
John (UK)
09-26-2004 11:42:25
 Re: Govenor and Timing cover in reply to Bill In Markham, 09-26-2004 03:59:28
Now I have read your other message I know what you have now. You have a Standard Carb engine 85mm bore. I have never heard of anyone doing that or the need for it, providing you change the oil regularly and keep the correct level, there is no problem with lubrication of the timing chain, sprockets or governor
John (UK)
09-26-2004 11:30:33
You don't say which engine you have.
