Hall Lamp headlight questions. Several pics.
Jim.UT
02-05-2005 21:06:01
This may take awhile to load all the pics. Please be patient. I bought a box of what was advertised as Ford headlights, but when I got them I found 3 or 4 Hall lamp lights that I've not seen on a Ford before. I'm wondering if these were originally on a Ferguson and if so, which model(s)? Take a look at the pics and let me know what you think. Thanks!
third party image
The ground wire is attached to the outer ring. The outer ring is held on to the main body with two screws through the front.
third party image
The sealed beam lamp is held in place in the outer ring with 3 or 4 spring clips. I only put two clips in place for this photo. There are two more clips on the garage floor under the tape measure. Anyone know where more of these clips can be had?
third party image
The overall shape is kind of conical like the old Tract-O-Lites on the N-series Fords. The mounting base is the same as the round style used on the later 8N's and newer Fords rather than wing mounts.
third party image
This shows how the outer ring which holds the lamp is attached with two screws to the main body.
third party image
Last picture. This shows a close up of one of the spring clips. One of these lights had 4 clips holding the lamp in and another had 3 clips, but 2 other lights had no lamp and no clips so I could use more clips. If you know where these are sold I'd appreciate the information.
All of these lights have "HallLamp" stamped in a diamond shape at the back near the base. Thanks in advance for any info you can give.
Pete in WV
02-08-2005 18:34:52
 Re: Hall Lamp headlight questions. Several pics. in reply to Jim.UT, 02-05-2005 21:06:01
I just got done rebuilding all my TO-30 lights and converting them to 12 volt. I got a complete bag of retaining clips from my local M/F dealer, I think there were 10 in the bag and cost appr. $6.50.
Jim.UT
02-11-2005 12:43:06
 Re: Hall Lamp headlight questions. Several pics. in reply to Pete in WV, 02-08-2005 18:34:52
I tried my local MF dealer. He said they were available (although he didn't have any in stock) and that they came 10 in a bag (I knew that). The price he quoted was $6.09 PER CLIP!! I asked him to confirm that was the per clip price and not the per bag price. He insisted that was the price per clip and I would have to buy 10 of them. So either your dealer made a mistake or mine is making a mistake. Needless to say, I walked.
Jim.UT
02-08-2005 20:49:26
THE DEALER!! What a concept. Why didn"t I think of that? You don"t happen to have the part number handy, do you?
Pete In WV
02-13-2005 18:26:04
 Re: Hall Lamp headlight questions. Several pics. in reply to Jim.UT, 02-08-2005 20:49:26
My dealer also tried to charge me per clip. I asked him if the bag looked as if it had $65.00 worth of clips in it and he agreed that it didn"t. So he checked his computer again and found that he had made the mistake as they were priced per bag, not per each.
pjfenner
02-06-2005 21:17:50
Jim, nice pictures for the questions. Yes, these are Ferguson lamps for the front. Suitably painted to match the correct tractor paint these could be mounted on any Ferguson TO20 thru F40. These particular ones have stamped bezels so are a little later probably for late 30 and on. Early bezels were cast and not so subject to he corrosion shown. But they appear to be restoreable and the clamps were 4 to a lamp assy and the ones for Ford mentioned in the responses will be ok or as some have said you can make your own from spring steel material.
Phil (WA)
Jim.UT
02-07-2005 06:43:47
 Re: Hall Lamp headlight questions. Several pics. in reply to pjfenner, 02-06-2005 21:17:50
Ah, nice detail....stamped vs cast bezel. That helps narrow it down. As some of you may have guessed, I'm getting these ready for resale and I wanted to be able to represent them accurately.
shannon from ohio
02-06-2005 18:10:02
Worked on a TO-35, Same exact setup. Hall headlamps with the clips and groundwire to the ring??
Mike Mohrhauser
02-06-2005 18:00:06
I show the retainer clip in my Dennis Carpenter catalog. You can get a catalog at www.dennis-carpenter.com.
Mike M.
CNESLER
02-06-2005 14:42:26
I reacently made clips from paper clips.
It took several try's to get the shape
with pliers but they are never seen from
the outside
Good Luck
CNESLER
Dean in Logan OH
02-06-2005 10:13:16
Paul,
A while back I posted this same ? on the forum about the clips. I forget who, but someone told me to check "info@dennis-carpenter.com" or phone (704) 786-8139. He deals in mostly repro Ford stuff but things like this are fairly universal. I havn't got around to checking yet so can't say for sure.
The lights on my TO35 were held in place by a piece of foam rubber someone used to replace the clips. The headlights in your pix look just like mine.
Paul in Ms
02-06-2005 04:37:10
These should be the factory lamps for the to-20, to-30 and possibly the to-35. As for the clips I don't have a clue as where to get them.
Jim.UT
02-06-2005 07:21:24
 Re: Hall Lamp headlight questions. Several pics. in reply to Paul in Ms, 02-06-2005 04:37:10
Thanks! That at least confirms what I suspected. Now at least I know what to ask for when looking for the clips.
