Hall Lamp spring clip revisited
Jim.UT
02-07-2005 20:39:45
third party image
Follow up question on these Hall lamps I have, specifically the bulb retaining clips:
I checked out Dennis Carpenter's website as suggested by some of you, but all I could find were the bulb retaining clips for the worklight. Those are much smaller than the ones I'm looking for. If any of you have bought the Hall Lamp headlight retaining clips from Dennis Carpenter, do you have a part number? Or a price?
I'd like to find out what exact reproductions will cost before I start bending paper clips.
Thanks
Zane(WA)
02-08-2005 13:51:19
 Re: Hall Lamp spring clip revisited in reply to Jim.UT, 02-07-2005 20:39:45
Replacement clips can be made from 'piano wire'. Piano wire can usually be had from a hobby supply store that carries radio control building supplies. It's sold in three foot lengths and doesn't cost very much.
Jim.UT
02-08-2005 11:04:51
I sent Dennis Carpenter an email along with a couple of pictures asking how much for the clips. I got a response saying "We don't have those". So, I guess I'll be using some needle-nose pliers and some paperclips!
Jim.UT
02-08-2005 13:21:24
 Re: Hall Lamp spring clip revisited in reply to Jim.UT, 02-08-2005 11:04:51
No, I've seen those before, too. The ones I need are at least twice that size. The 8N15534 are for the CM Hall implement light that has the bulb soldered into a reflector.
The ones I'm looking for hold a sealed beam lamp in the large Hall Lamp headlights. Scroll down the page a bit for my post with all the pictures.
r taylor
02-08-2005 12:38:56
jim the part #is 8n15534
