Governor adj
clearfield
05-28-2005 18:34:22
Hello group Recently I removed my head on my 52 TO-30
had the vavles resurfaced along with new stem seals new head gasket and coolant inlet gasket everything went back in place all linkage hooked back up as before did not have any linkage removed just the governor spring on the water coolant inlet which I just layed aside to keep out of the way Now my problem is the governor does not advance my idle as it did before when I come to a small grade or hill it alway work so well before
I double checked to make sure I had everything back in place and hooked up but can't see anything out of place tractor run really well idles good and no miss
I have a Ferguson shop manual by I&T there is a section in on how to adj but not a real clear discription.
HELP
clearfield
