Great Weekend ,Part 1
Jeff-oh
09-06-2005 06:15:34
This past Holiday weekend (US Labor day, Sat-Mon) was great. My wife and I went out to the country place, I cannot rightfully call it a farm, as nothing is done there, and with respect to all who truly work the land for a living. However, it was part of a 100-acre tobacco farm prior to 1990.
Anyway, I started out by draining and flushing the radiator on my '48 TE-20. I could not find the drain plug on my radiator and had to pull the lower hose to drain. I have a fan shroud and was not sure if that obscured the plug or not. I did find a plastic plug on the bottom in the middle, however it was so tight that I was concerned I would break it before it came out.
I was also installed a thermostat in the upper hose as my tractor did not have one.
With this maintenance done I was off and mowing. I cut about 3 acres in just over an hour in 3 gear.
When I parked it the hydraulic lift would not raise. Curious...
