Generator Output
Tsim
09-07-2005 11:51:42
Does anyone know the maximum design ampere output of a 1948 TE 20 generator?
I am going to build a solid state voltage regulator to increase output to 12 Volts, but I need to know the maximum design current for the generator so I can limit the current to a safe value.
Thanks,
Terry S
George in Mich
09-07-2005 15:18:28
 Re: Generator Output in reply to Tsim, 09-07-2005 11:51:42
I think the max output is around 15 amps at 6 volts on the TO-20, often they are more like 10-12. Not sure if this is the same for TE
tsim
09-07-2005 16:59:02
 Re: Generator Output in reply to George in Mich, 09-07-2005 15:18:28
Thanks for the info, George.
Presuming 15 amps is max, I will use 12 amps to be on safe side.Not much load on the system anyway;ignition coil, lights etc.
Heaviest load will probably be recharging battery after starting.
Jim W
09-08-2005 06:16:42
 Re: Generator Output in reply to tsim, 09-07-2005 16:59:02
TEA generator output is 11 amps; I suspect TE is too as they are both Lucas systems.
Jim
tsim
09-08-2005 13:40:04
 Re: Generator Output in reply to Jim W, 09-08-2005 06:16:42
Thanks Jim. 11 Amps will be max. to be on the safe side.I had rather undershoot than overshoot.
tsim
john (UK)
09-08-2005 09:24:51
You are correct Jim it is as you thought..11-13amps. The original generator on a TEA was the same as on the TE, they changed it later.
