HIgh voltage?
RegoR
10-17-2005 17:26:11
I just replaced a non-fuctioning amp guage with a volt meter which indicates about 14V at idle and pushes 18V at higher revs. I confirmed this with a digital VOM. The Delco-Remy voltage regulator looks to be original for this '57 TO-35. It has two adjustment screws at opposite corners, but I've never tinkered with one.
First, is the voltage excessive?
Second, if so, can this be adjusted? How? OR, if so, should I replace the VR?
Last, does this need to be an exact MF replacement?
Thanks in advance.
RogeR
gerard
10-18-2005 06:12:43
 Re: HIgh voltage? in reply to RegoR, 10-17-2005 17:26:11
Max voltage on a non-sealed battery, 14.9v - lower for sealed, c. 14.2v.
