Yes!!! Cheers!!!! Your input and TEA stories are always fun. If I may, let me make one more attempt to explain how these things work. Picture yourself at the controls. If you want the lift to rise you pull the Quadrant control (QC) aft, or a Counter-clockwise (CCW) rotation looking from the tractor's right side. The responce is the lift arm moves up... a clockwise (CW) rotation. If you want to lower the lift you push the QC forward, or a clockwise rotation, again looking from the tractor's right side. The responce is the lift arm moves up... a counter-clockwise rotation. All the position controls hard link the input lever and the lift arms together. Thus as the lift drifts up (clockwise rotation) it forces the QC to rotate Clockwise also... but remember, a clockwise rotation of the QC is a command to lower the lift. Thus, the lift is commanded to lower to its originally set position. The opposite is also true. If the lift drifts down, (a CCW rotation) is pulls the QC in a CCW rotation with it. Again, a CCW rotation of the QC is a command to raise the lift. Thus, the lift is again returned to the originally set position. Hope this helps. Jeff P.S. my fishing trip last summer up past Wawa was fantastic. You all have some beautiful (and very remote) country up there
