Front wheel weights tire pressure
Steve (DE)
04-26-2006 08:59:04
I just put a set of (inside) front wheel weghts on my TO-20. Total weight is 90# on each wheel. They are 6.00-16 tires. What is the proper tire pressure for this?
I put the weights on to balance a Towner 2120 Offset Disk Harrow which I am going to try out for the first time. The disk weighs 870#, and without the weights the front wheels just about touch the ground..steering is a bit odd.
Thanks for your help.
Boss Hog
04-27-2006 05:05:56
 Re: Front wheel weights tire pressure in reply to Steve (DE), 04-26-2006 08:59:04
I run mine at 35 PSI. That's the max pressure allowed on the sidewall printing.
You could probably get by with a lot less. But I'd be concerned about damaging the sidewall if it flexes a lot with extra weight on it.
John (UK)
04-27-2006 08:15:01
 Re: Front wheel weights tire pressure in reply to Boss Hog, 04-27-2006 05:05:56
For a standard tractor without a loader fitted, the recommended pressure is 26lbs.psi. if you have a loader you do increase the pressure.
John (UK)
04-26-2006 10:54:26
Tyre Pressure is 26lbs.psi
