Furnace Brazing
Robert Plyler
06-07-2007 11:36:27
Does anyone know where I can get my to30 block furnace brazed here in the south east? I am located near Charlotte,NC. Any info will be appreciated,. Thanks
mike dixon
06-07-2007 19:56:15
 Re: Furnace Brazing in reply to Robert Plyler, 06-07-2007 11:36:27
Hi, I live in Yadkinville, about 1hr 15 min north of Charlotte. I could not find anyone in my area of Winston Salem and Greensboro to do the furnace brazing. I took the block to Key block in Greensboro to see if they could pin it but it was cracked to bad. Cracks both top and bottom. So after many miles and phone calls I decided to weld the cracks up with 2-24 nickel rods. I ground out half of the cracked material in each crack and welded it. I let it set a couple of days and then ground out the remaining material and welded it up. Then I repeated this process on the cracks on the bottom. I now have the block at the machine shop to be fly milled and then surfaced. I will let you know if this works.
John(UK)
06-07-2007 11:48:24
Look further back on this page for "Crack Saga" you may find something there....John
