Good Tractor Cover
Ron Lindquist
01-10-2008 06:08:10
Looking for a source to get a good waterprofe and breathable cover, for my TO-20,TO-30, and MFTo-35 gas tractors that have to sit out side.
Thanks,
Ron
eugene stevens
01-10-2008 15:28:44
 Re: Good Tractor Cover in reply to Ron Lindquist, 01-10-2008 06:08:10
RON ,FOR THE COST OF 3 GOOD TARPS YOU CAN GET ON SALE AT ANY PEP BOYS A PORTABLE CARPORT 10X20 FOR < 100.00. GOOD LUCK
Bob (Aust)
01-10-2008 11:58:58
The rubber gear lever boot off the MF35 (I think it is) fits the TEA20 perfectly (and I am sure, the TO20 and TO30) and stops water entering the gear box via the gear lever.
I think it is Part No 13417B available from this site HERE.
The other source of water in the transmission is usually via the depth control spring, behind the seat.
Interestingly, Ferguson sold a tractor cover accessory no A-TE-A68. "Ferguson Implements & Accessories" (Page 110) says:
"The cover extends only over the bonnet to the rear of the seat. It is made of waterproof canvas, with brass eyelets and strong cords for tying it into position"
I am sure I saw a photo of the cover, think it was somewhere on the FENA web site.
Jeff-oh
01-11-2008 09:04:56
 Re: Good Tractor Cover in reply to Bob (Aust), 01-10-2008 11:58:58
Sparex still supplies the type of cover bob discusses. it is
S.60175 Tractor Cover - Brown Universal
You can see their drawing at the web site. It is on page 2 of the last section of the catalog. "Sheet metal"
Jeff-oh
01-10-2008 06:41:14
third party image
Right wrong or other wise, I use a plastic tarp. 11' by 8' place it over and either steak out the corners like a tent or wrap the tarp around the wheels and tie the corners together. Tarp is a foot or two off the ground and so I get some air circulation.... Works for me.
The other thing I always do is I put a pail (cat litter, or dry wall mud bucket) over the gear shift levers to help keep the water out of the tranmission case and wrecking that oil.
These pails are a little smaller than a standard 5 gallon bucket and a deep enough to cover the shift levers and sit down on the tranmission housing, yet short enough to slide under the steering wheel.
Here is a picture of the one I use. I have seen then used for many different products.
