TO30 Manifold
Lewis Mills
01-14-2008 08:10:05
I've lost my manifold. I'm restoring my dad's TO30 and can't find the manifold. I have a neighbor boy clean up my shop about once a month and I suspect he has thrown it away, but I don't know. I've looked everywhere, no manifold. Does anybody know where I can get one without buying an after market one? Any help will be appreciated.
Lou
GrampaJack
01-18-2008 05:46:14
 Re: TO30 Manifold in reply to Lewis Mills, 01-14-2008 08:10:05
I got a repro manifold for the TO20 from this site, and although it was different from the original, it was an excellent casting and worked great. The casting for the bearing housing on the PTO shaft assembly I got here was not nearly as nice with lots of voids. It will work but not nearly as impressive as the manifold. Jack
Lanse
01-14-2008 17:59:44
 H I !!! in reply to Lewis Mills, 01-14-2008 08:10:05
You could just call a salvage yard. Should have some unexpensive ones
Lance J.
01-14-2008 15:30:19
Lewis-
Just to let you know, user MattMalcome1 posted a week or two ago stating that he is parting out some Fergusons, I think one was a TO30. His post is 2 or 3 pages back. I bet he would have a manifold for you.
Lewis Mills
01-16-2008 06:07:02
 Re: TO30 Manifold in reply to Lance J., 01-14-2008 15:30:19
Thanks Lance. I'm buying some other parts from Matt but he doesn't have a manifold.
gshadel
01-14-2008 14:01:57
Ebay or tractor junk yard are about your only options for an original manifold. My guess is most are going to be rusted REAL bad. I installed a new after market manifold a few years back. I think the original style does look better, more "streamlined" or whatever, but once you lower the hood, can't tell the difference. The after market ones have a few bolts that are tough to get a wrench on the them, but the fit is good.
George
Lewis Mills
01-16-2008 06:09:49
 Re: TO30 Manifold in reply to gshadel, 01-14-2008 14:01:57
I've been thinking about an after market manifold but I wanted it as original as possible. I may have to go that route.
Thanks
Lance J.
01-14-2008 13:24:46
Just wondering, why do you wish not to go with a new manifold? Unless you can find a "new old stock" unit, any used manifold is just waiting to crack the first time you bolt it up.
Lewis Mills
01-16-2008 06:14:04
 Re: TO30 Manifold in reply to Lance J., 01-14-2008 13:24:46
Thier appearance is considerably different and I'm restoring this tractor for appearance, I'm probably not going to use it, certainly not much anyway, but I'm not ruling out using an aftermarket manifold, I just want to see what I can get original.
Thanks
jeff-oh
01-14-2008 12:15:31
Watch e-bay for the guys who part out tractors.
Lewis Mills
01-16-2008 06:16:11
 Re: TO30 Manifold in reply to jeff-oh, 01-14-2008 12:15:31
I been doing that and none have been posted that weren't cracked or repaired.
Jeff-oh
01-16-2008 06:39:12
 Re: TO30 Manifold in reply to Lewis Mills, 01-16-2008 06:16:11
You do have to be patient as they do come up from time to time. I have a good one I purchased. I want to use it to replace the one on my TE-20. The TE-20 does have a weld repair.
Hey the hunt for the perfect part is half the fun.
Letting people know what you want/need is also a good way to go.
Lewis Mills
01-16-2008 08:55:51
 Re: TO30 Manifold in reply to Jeff-oh, 01-16-2008 06:39:12
Yeah, I've had two people e-mail me with exactly what I want but the price is more than I want to pay. I can get an after market much cheaper. The decision I have to make is how badly do I want to keep it original. Not unlimited funds if you know what I mean. Ha.
Dan S (NY)
01-16-2008 09:56:30
 Re: TO30 Manifold in reply to Lewis Mills, 01-16-2008 08:55:51
If you get a new aftermarket one, check as best you can in the passages for chunks of slag or other junk. I fished out a fairly large chunk of metal slag from one of the passages on mine before I put it on. My TO20 seems to run better with the new style manifold, either from new gaskets or better design I'm not sure.
Dan
Lewis Mills
01-16-2008 11:10:23
 Re: TO30 Manifold in reply to Dan S (NY), 01-16-2008 09:56:30
Thanks Dan, appreciate the info.
Lou
