Order Ford 4000 Parts Online
'68 4000 fluids
Varner
11-16-1999 00:17:42
Been getting conflicting info on types of fluid to use in my '68 4000 gas, need to know what to use in: 1)power steering, 2)Select-O-Speed, 3)differential. Also my tractor currently has an automotive battery in it, is there a better choice?
Bern
11-16-1999 07:43:52
 Re: '68 4000 fluids in reply to Varner, 11-16-1999 00:17:42
Use Ford New Holland 134 oil or its equivalent in all 3 reservoirs you mentioned. Period.
An auto battery is probably good enough for a gaspot. Would likely be too small to start a diesel on a cold morning though.
Ken
11-16-1999 05:53:01
I can tell you that I used type 134 on my 4000 for 8 years without any problem. It went into everything (at the recommendation of the mechanic at the ford dealer) Never had problems with the SOS from there on, but I did take his advise and did regular (yearly) changing of all the fluid (espically the SOS). As to the battery, I also had a car battery and it worked fine for the last 4 years I owned the machine. I helped the city farmer this year when he got stuck and it still cranked her over with power to spare.
