Slow lift
billy
01-14-2003 15:57:09
got a 841 ford 61 model good shape but the lift is real slow in cold weather better when it warms up replaced oil with komamsue hyd oil didnt help bleed pump better for a while think could be pump if so how hard to rebild and where can i get parts thanks billy
OLD FORD MECHANIC
01-22-2003 10:13:23
 Re: slow lift in reply to billy, 01-14-2003 15:57:09
DRAIN LIFT HOUSING,REFILL 3 OR 4 GALLONS KEROSENE OR DEISEL FUEL.START TRACTOR AND USE LIFT AND/OR REMOTE VALVES SEVERAL TIMES.DO NOT DRIVE OR MOVE THE TRACTOR. LET THE SYSTEM WARM UP FOR SEVERAL MINUTES AND CONTINUE OPERATING THE CONTOLS.BLEED THE PUMP TO REMOVE AIR FROM THE SYSTEM.THIS WILL FLUSH DIRT AND MOISTURE OUT OF THE SYSTEM.IF THE PUMP AND OTHER COMPONETS ARE OKAY THE SYSTEM SHOULD SPEED UP AND WORK PROPERLY.DRAIN SOLVENT AND REFILL WITH NEW OIL. HAVE DONE THIS MANY TIMES WITH GOOD RESULTS.
RANDY
02-09-2003 05:17:01
 Re: Re: slow lift in reply to OLD FORD MECHANIC, 01-22-2003 10:13:23
I HAVE A 6600 AND MY LIFT IS SLOW AND WEAK,I CAN RUN MY RPM,S UP AND IT WILL SPEED THE LIFT UP A LITTLE ,BUT OVER TIME IT IS GETTING SLOWER. IS SOME WHAT BETTER WHEN ITS WARM
Tom
01-16-2003 13:08:06
Agree with Jeff. Get the Manuals - - 3 of them. and get originals from dealer or copies - not offbrand ones. 1. Operater Manual 2. Repair Manual 3. Parts Manual. You need all 3 if you are going to do any of your own work. Sometimes only the Parts Manual with its exploded views will bail me out.
Jeff
01-15-2003 06:26:11
Hey Billy.
I'm no hyd. expert but Iv owned a few old tractors and currently have a '64' Ford 4000 Ind. that I work on from time to time. My 2Cs is this: go on line here and buy an I&T manual that includes your model tractor or contact Jen-Sales on the internet for a copy of the original. Read up on the hyd system, trouble shoot it then decide if you want to tackle it. At the very least you will arm yourself with some hyd knowlege. Then you'll know what you are dealing with. Good luck, hope this helps.
