Order Ford 3000 Parts Online
'67 3000 frozen clutch?
Pam
05-19-2003 09:24:14
Parked it in the garage to work on power steering for a few weeks, now can only get it in gear when tractor is off. It's been suggested the clutch is frozen . . . anyone got any ideas on how to "break it free"???
Pam
05-27-2003 17:35:12
 Re: '67 3000 frozen clutch? in reply to Pam, 05-19-2003 09:24:14
WOO-HOO!!!
I just wanted to let everyone know, after trying everything y'all suggested, the clutch is now free. Much cheaper and less time invested than splittin' the thang. . . . THANKS SO MUCH!!!
Jack
05-21-2003 17:30:25
Pam
You need to put a big load on the tractor-drag something like a plow, your mother-in-law, etc-while holding the clutch pedal down. Drive it around and get it good and hot. That should do it.
Pam
05-25-2003 16:06:38
 Re: Re: '67 3000 frozen clutch? in reply to Jack, 05-21-2003 17:30:25
hmmmmm . . . never thought about the mother-in-law, i mean, pulling a heavy load. i'll give it a try!!!
thanks!!
RWK in WI
05-20-2003 18:56:39
To keep it from happening put a block of wood between the clutch pedal shaft and the bottom of the running board to hold the clutch disengauged when it is parked.
I have had luck freeing the clutch by driving the tractor while holding the clutch pedal down. Be sure you do it where there is plenty of room.
Pam
05-25-2003 16:07:51
 Re: Re: '67 3000 frozen clutch? in reply to RWK in WI, 05-20-2003 18:56:39
will give it a try!!! thanks!!
david
05-19-2003 12:25:59
Heard a lot of ideas over the years. Only one I know works (without the potential to really tear up something)is to split the tractor.
Pam
05-20-2003 05:54:49
 Re: Re: '67 3000 frozen clutch? in reply to david, 05-19-2003 12:25:59
I will try, hate the thoughts of having to split the thang everytime it sits still for any length of time. Thanks!
Free Bird
05-20-2003 07:26:32
 Re: Re: Re: '67 3000 frozen clutch? in reply to Pam, 05-20-2003 05:54:49
Do a search on stuck clutches, I think Bern has a solution for getting them unstuck.
Gary
05-19-2003 17:03:25
Had the same problem but after some use and a lot of clutching strokes it finally broke loose, may of been only luck but it worked for me. Its not the best thing but at low idle you can put it in gear, Low and say four at the same time with no gear grinding. Then use it to free it up. Good luck.
