Order Ford 9N Parts Online
9N Fuel problem?
bill
07-12-2003 09:39:04
I am looking at a 9N for sale. It will start only if it is fully choked, that is, with the air intake hose off you hold your hand over the intake to the carb. It won't smooth out and quits as soon as you take your hand away. The owner has placed a new fuel line with filter from the tank to the carb. It has not run in at least two years but ran when parked. It looks clean and has been inside it's whole life. My guess is dirt in the carb or maybe a plugged jet restricting fuel flow. Any thoughts from you Ford people out there??
Pete Molinet
07-12-2003 10:42:46
 Re: 9N Fuel problem? in reply to bill, 07-12-2003 09:39:04
Bill I had the same problem with my 600 Had carb overhauled and my fuelbowl cleaned and now everthing is fine Goodluck.
Pete
brownie
07-20-2003 13:58:23
 Re: Re: 9N Fuel problem? in reply to Pete Molinet, 07-12-2003 10:42:46
rebuild the carb & it will be fine
