I've had a couple tht were stuck.. on one.. the prev owner put a small 'blip' of weld at the casting to rod area to prevent it from turning. All i had to do was gring it out. On the other, 50ys of hard grease and dirt and some rust got to it. I took it of fthe tractor and turned it upside down and soaked with PB blaster, then set in a shallow tray with some diesel and atf fluid in it... left it that way for a day.. Came back set it on my anvil, and gave some medium whacks downt he side of the casting.. nothing bad.. just whack.. though i did use a non maring copepr hammer. For kicks.. try greasing the joint.. may or may not take any. In any case. then i heated the fork with a propane torch.. i had the rod clamped in the vice and once i got the casting hot enough to smoke the grease and oil in it, i put a pipe wrench to her and she unscrewed fine... though sticky. Washed parts in washer, and chased old threads on rod and in casting as best I could.. then i heated the rod and bent int he vice.. touched up rod with a file to take vice marks out, changed out grease fitting for good measure, shot some grease in it.. then greased rod and threaded in.. cleans up crank box and regreased as well. Had another that needed extensive welding and thread work.. but that's another story.. Still got the 2 i rebuilt.. workin' fine.. Soundguy
