Front end loader
Charlie C.
02-23-2008 16:08:20
Hi Guys, another question or two.
I have a lead on a ford loader but do not know what model it is. Maybe if I give a few details from the pictures I have you might make a guess as to the model.
Also any things that I might want to watch out for when I am looking at it.
At present the loader is mounted on a 4000 with a SOS trans. The transmission is bad. I am not interested in the tractor any way.
The tower on the right hand side of the tractor, where the lift cylinder and the loader arms connect , is a hydraulic tank. The bucket is operated with two cylinders. The frame work reaches back under the tractor and anchors to the axles.
The hydraulics are plumbed into the tractor remote hydraulics. It does not have a second pump for the loader.
As always any information or advice will be appreciated.
Charlie
Charlie C.
02-25-2008 16:26:35
 Re: Front end loader in reply to Fordfarmer, 02-23-2008 16:08:20
I will bump this back up one more time to see if any one else has any input.
Thanks.
Charlie C.
02-24-2008 11:43:48
 Re: Front end loader in reply to Wally Verbeck, 02-23-2008 16:08:20
John this is a picture of the loader right side. Maybe this will help.
third party image
This is as small as I can get the picture and still see any details. There was a decal in the black area of the arm. Reducing the pic pretty well obliterated the decal but it is ford.
Charlie C.
02-23-2008 18:16:03
 Re: Front end loader in reply to WMKoch, 02-23-2008 16:08:20
John thanks for the reply. Now I know what will help you guys in identifing this loader.
The frame goes under the axle I think. The frame is lower than the running board.
I would guess that the lift arms are boxed as they look more square than a round configuration, maybe this was not what you meant.
The front has a rectangle tube reaching across the front of the radiator connecting the two side rails. The two bars that reach from the tower to the radiator appears to be open as opposed to having a plate welded over the end closing the tube.
Hope this will give you some help.
John Ia
02-24-2008 10:11:39
 Re: Front end loader in reply to Charlie C., 02-23-2008 18:16:03
Charlie, this is a guessing game.The info you gave doesn't help a lot. You didn't say anuthing about color, Just that the loader is mainly squared off. It's not a dearborn as most of them are round pipe frame. But it could be a Paulson Wagner Freeman or a Ford. And you didn't say weather the 4000 was a utlity or row crop. You said it has a hydraulic bucket, 2 cylinders. My GUESS is it's a ford model 711 or a 701 trip bucket converted to hydraulic. John
JohnIa
02-23-2008 16:31:33
 Re: Front end loader in reply to Charlie C., 02-23-2008 16:08:20
Charlie, We need more info: !'st all loaders on early fords mounted to the rear axle, On top or bottom.2nd, you didn't say weather the front was rounded or boxed, this would give us a guesstimate of the year pre65 or post65. 3rd The only thing we can guess at is Where it's run off of tractor hydraulics and not a front pump it's on a row crop tractor with or without a wide front?Unless its a 4000 utility. Last most loaders have a manufacters tag on the left up right some where. Sometimes they get painted over, look for a 2x3inch square rise in the paint and scratch lightly with a knife , your model number will be on the tag. John
