15 inch Ford tractor wheels
Jim.UT
04-09-2008 08:28:33
third party image
I have a Funk 8N with small front wheels. I looked closer at them last night and found out I have 15 inch wheels and tires, but the wheel is the same style as the 16 inch wheels on my 850, complete with two sets of mounting holes and 4 wheel weight holes.
What tractor would these have come off of?
JohnIa
04-09-2008 18:42:31
 Re: 15 inch Ford tractor wheels in reply to Jim.UT, 04-09-2008 08:28:33
Jim, I beleive those are implement wheels. If you look at a pair of ford front rims you'll see that the weight holes are round not square. I have several sets of 15 inch like those on a M/F hayrake a stanhoist elevator and a couple of light wagons. John
Ultradog MN
04-09-2008 17:15:35
third party image
They might not have come off anything in particular.
I went to Pioneer rim and wheel and asked for a pair of 6 on 6" 14" rims. I don't remember how wide these are but they had them in stock.
Tires are 195/70R14.
Fordfarmer
04-09-2008 13:42:30
4200's and 5200's have 15" front wheels as standard, but that wouldn't explain the yellow paint. I don't know if any of the industrials have 15"s or not. Lots of equipment uses 15", some have the double lug hole pattern and/or weight bolt holes, some don't. New Holland implement wheels are yellow, as well as JD, PMC (Pequea Machine Corp.), and probably a few others. Might the smaller wheels have been put on to lower the front end? The Funks that I've seen all had higher hoods than stock 8N's.
old
04-09-2008 09:30:08
Well since you can see yellow paint on them I would say they came off an old JD baler. A lot of the old JD balers like the 14T and 24T used a 15 inch wheel that will bolt right on to a ford BTDT a few times just to get by when I had a flat on my 841
Joe(TX)
04-09-2008 09:25:30
Probably off of some implement
