Brian Allen
I finally have the duals installed, with two more trips to the tire dealer.
I had to replace the "J" bolts as the old ones were about 3" too short.
I then cut 1 1/2" off the new ones, and they fit great
The duals are fairly easy to install once you get the hang of it.
I also noticed it is hard to judge where the outside dual is, when you drive in through the garage door! oops!
I have two clamps that are JD green, they may get painted some day!
I also replaced the power steering pump filter and re-installed the straightened front tin-work today after I took the picture.
Brian
Brian
