Fordson Tractors Discussion Forum
E27N gear box
adam w
06-09-2005 03:09:20
I have a Fordson E27N 1948 with a standard 4.3
gearbox , but where the belt pulley is normally
fitted mine has a gear fitted with a lever running up to the dash area and is marked High /low , does this turn the 3 speed into six or just one gear only ?
Does it have any special name?
j alexander
11-19-2005 21:45:38
 Re: E27N gear box in reply to adam w, 06-09-2005 03:09:20
I recently saw a derilict fordson , the only ID icould see was plate which reads 4.3 LOW GEAR.The ser no starts whith 11. How rear is this tractor?
BarryM
06-09-2005 21:29:31
Adam,
Is this an Australian tractor? If so, it will be a Maidrite Underdrive or Overdrive. As yours is this 4.3 low speed, it will probably be an Overdrive. This will give you 6 forward & 2 reverse. The unit was made by Southcott Engineering of Adelaide. If you look closely at the Gear Change it will have Part No's starting with AB stamped in.
Brenton S - Adelaide SA
06-11-2005 03:32:57
 Re: E27N gear box in reply to BarryM, 06-09-2005 21:29:31
Adam, I am from near Adelaide aust and recently at a sale I saw an e27n set upthe same way, and the previous owners brother told me that it had been put in the tractor by Southcott Engineering, so I would suggest that what BarryM says is the same as I have heard
