Fordson Tractors Discussion Forum
power major front main?
A.I. Guy
03-31-2006 18:24:25
I am leaking oil from between the plate behind the fan and engine. I assume it is the front main seal? The power steering box is also leaking.But before I tear it appart. Where can I find gaskets and parts? This is my first Major pulling project and its turning out to be a major pain to find parts. I got it running and driving great and I may just clear up these leaks and sell it to someone finish it and appreciate it.
Majorman
04-01-2006 01:15:13
 Re: power major front main? in reply to A.I. Guy, 03-31-2006 18:24:25
No that is not the front main oil seal. This is just a mounting plate with a paper gasket behind. The bolts work loose and the plate starts to leak. You can fit a new gasket in about a day,we used to do it easily in 4 hours. All the timing gears etc. have to come off but that is no hastle.
Majorman
04-01-2006 01:53:16
 Re: power major front main? in reply to Majorman, 04-01-2006 01:15:13
third party image
Here are a couple of pictures from my Major which might help.
Majorman
04-01-2006 01:56:20
 Re: power major front main? in reply to Majorman, 04-01-2006 01:53:16
third party image
Cover removed
Majorman
04-01-2006 01:58:22
 Re: power major front main? in reply to Majorman, 04-01-2006 01:56:20
third party image
Removing the axle assembly, Sorry did not come out first time.
