Super Dexta rear axle oil seals
allen Johnston
08-01-2000 20:07:27
I am going to have to replace both of the right rear axle oil seals. I understand that I have to chisel off a collar that needs to be heated/pressed back on. How difficult is it to get the axle out? One man job or two? Any gotchas or tips? I am planning to get started this saturday, so I would appreciate any replies that you might have. Thanks!
Oscar
08-03-2000 04:43:38
 Re: Super Dexta rear axle oil seals in reply to allen Johnston, 08-01-2000 20:07:27
I haven't actually done that repair myself. I'd say it can be done by 1 man. I'd avise you to get hold of the service manual first, because from reading that manual I don't think this is a repair you can pull of "just" with common sense.
Tip #1: you have to drain the oil from the rear axle of course. I did that once, shoved a bucket under it and pulled the plug. Thing is, there's 20 litres of oil in there. So you better have a BIG bucket handy (I didn't....)! Also make sure the oil does not get contaminated with dust or sand while out of the tractor. The hydraulic pump needs very clean oil! So check the oil before pouring it back in, and replace it if necessary.
Tip #2: as general safety precaution, crick up the tractor, but before you take the wheel off place a metal or wooden post under the axle, don't leave it just on the crick alone. Also put a few blocks of wood under the other wheels. You do not want the tractor to move while working, and a crick is meant to lift the tractor up, not to support it while working.
Best of luck. I'll see if the manual has a few useful things to see about changing these seals.
Regards,
Oscar
Burrhead
08-03-2000 13:29:07
 Re: Re: Super Dexta rear axle oil seals in reply to Oscar, 08-03-2000 04:43:38
Good to see you back Oscar. Your right but it is a one man deal. Crick it up huh?? Over here a crick is a small running stream.
When you get the axle out turn it upwards with the spline sticking straight up. Preferably in a vice.
Now take a 3/8" or so drill and drill a hole throught the retainer collar. Now take a sharp chizel and break the collar. Slip the retainer out of the way and the bearing should peck off with some effort. If it wont give then press it, but don't hammer it too hard.
When you reassemble it the new retainer will have 1 way traction teeth inside it to make it lock down. Be sure you have the retainer on the shaft pointed in the right direction or the axle will come back out of adjustment when you move the tractor.
Between the back of the brake anchor plate and the axle are shims, be sure you don't bend or lose them.
Brian
08-03-2000 14:04:35
 Re: Re: Re: Super Dexta rear axle oil seals in reply to Burrhead, 08-03-2000 13:29:07
Burrhead,
In my part of England (Norfolk) a crick is something you get in your back when trying to lift axle shafts on your own without lifting gear. Or you get it in your neck by watching pretty girls in mini dresses on hot days.
regards
Brian
Burrhead
08-03-2000 20:29:35
 Re: Re: Re: Re: Super Dexta rear axle oil seals in reply to Brian, 08-03-2000 14:04:35
Yeah that's one of our terms too. You get a crick in your neck, and also you can take a bath in a crick.
When I saw the "put a crick under it" I LMAO because I could just see one of our friends in Arkansas pulling in the crick to work under his dexta.
