3 way lift not Strong
J.C. Eldr
02-15-2001 19:48:19
when I Hook up empliments to my model 35 Fergisont it will not hold the equi. up long
Burrhead
02-16-2001 10:40:15
 Re: 3 way lift not Strong in reply to J.C. Eldr, 02-15-2001 19:48:19
It could just be the pick up screen on the pump is dirty or it may have water in the oil.
Is it worse when it gets hot or is it the same cold and hot??
JCELD
02-16-2001 20:33:03
 Re: Re: 3 way lift not Strong in reply to Burrhead, 02-16-2001 10:40:15
It is worse when it gets hor &where is the screen located?
JCEldr
02-17-2001 14:38:27
 Re: Re: Re: 3 way lift not Strong in reply to JCELD, 02-16-2001 20:33:03
I hope BURHEAD can Answer My Question reguarding the elusive hydrolic SCREEN
Burrhead
02-18-2001 17:48:25
 Re: Re: Re: Re: 3 way lift not Strong in reply to JCEldr, 02-17-2001 14:38:27
Naw if it's worse hot then it's not the screen JC.
Maybe you can try thicker oil in it but it sounds like the piston ring or pump is wore out.
