MY DEXTA IS WORKING AGAIN ONLY ONE PROBLEM HELP ME
Alan
06-16-2001 07:48:20
OK so a few of you got a bit cranky with me over my dexta well its now working the steering is working but still is a bit thight only one probelm left and i need help with it i have a simms injector on mine and the peumatic govenor is still not working well it raises engine power and then lets it drop a few friends told me the system could be slow should i replace it or go for a maual one
Stephan
06-16-2001 10:23:49
 Re: MY DEXTA IS WORKING AGAIN ONLY ONE PROBLEM HELP ME in reply to Alan, 06-16-2001 07:48:20
Have you cleaned the line from govenor to the intake manifold? cleaned the air filter on the govenor? when you remove the govenor push it in en close the line conection with you thumb, it shoud stay in its position. if not you have a leak in the membrane.
I have 2 dexta's with the same problem just after start up. after a few min running the do fine
(at least for my purposes) I think the single line govenor of the dexta is less sensitif then the dual line on the FMD & FSM's. At least I never had problems with those.
Good luck
