Part # for a new Fordson F fan belt
ADAM
01-30-2002 20:28:56
I believe i stated that i would post this a couple of months ago. Well, i Finally got around to it (i finally remembered!) anyway, if you need a new flat belt for your Fordson F, and you are not a "purist", then go to your local auto parts store and ask for a Gates belt # K080427. This is a wide serpentine belt that is the correct length. Easy to install and tighten, no more belt slipping.last one i purchased was about $20.00 but it is well worth it.
Lamar Burd
01-18-2003 05:56:58
 Re: Part # for a new Fordson F fan belt in reply to ADAM, 01-30-2002 20:28:56
Thanks for the tip on using the Gates belt. My friend who owns this tractor tells me it worked out great. He plans to work on obtaining a leather version for show purposes but the Gates belt allows him to run the tractor and save wear and tear on any leather belt he might be able to buy (or make).
Thanks again. LB
