Engine Starter motor, URGENT HELP NEEDED
Alan
02-03-2002 02:56:05
I have a Fordson Dexta made in some time '73. I have a problem with starting i tryed it a few days ago it nearly started, then it seemed like the battery was run down, so i got the battery recharged, now then i engage the starter motor it makes a clicking sound but no turnover i have checked the battery which is a new 660 amp battery. It has worked fine in the past. Could it be a starter motor sticking problem, i need it on thursday of this week Can anyone help and can someone give me ideas on how to fix it please.
From, Alan
bernt sparby
02-08-2002 00:52:32
 Re: Engine Starter motor, URGENT HELP NEEDED in reply to Alan, 02-03-2002 02:56:05
Hi Alan!
There is a starter relay mounted under
the hood just above the starter motor.
You can operate it by pressing the
rubber rear end. It's cheep to replace.
I've had that problem and I bought me
a new one. Really cheep.
I'm from Sweden by the way but connected on the net every day. My job.
Carl
02-03-2002 06:06:37
Have you tryed jumping across your relay that is clicking, it could be bad; also check all your wiring connections, especially your ground.
