Dexta oil leak
Allen Johnston
04-28-2002 07:52:30
I have a 1963 Super Dexta w/3 cyl Perkins. There is an oil leak that drips from the brake pedal shaft where it runs through the body of the tractor. I thought that the area between the engine and transmission was dry. Any comments on what or where this might be coming from?
Peter Tatham
04-29-2002 00:36:11
 Re: Dexta oil leak in reply to Allen Johnston, 04-28-2002 07:52:30
Allen, Is the oil black engine oil or is it transmission oil? Your oil could be leaking from a failed crankshaft rear oil seal, which I think is most likely, or, the main drive shaft oil seal could be the suspect. Have you noticed any clutch slip - usually a sign of oil contaminated friction linings? Either way, if the leak gets worse and effects the operation of the clutch the only solution is to split the tractor and have a look.
allen johnston
05-02-2002 19:22:22
 Re: Re: Dexta oil leak in reply to Peter Tatham, 04-29-2002 00:36:11
I think it is coming from the rear diff area. It will leak until the oil in the rear diff drops below a certain point (below the level plug) then stops. It starts again when I fill the rear diff with oil. So it is coming from there. So far, no problems with the clutch.
