1923 fordson tractor
Dave
05-28-2002 18:53:20
I have just purchased a fordson tractor and was told it is a 1923. The last patent date is aug 1923, however I cant find any other numbers (serial #s) can anyone tell me where to look or is this all the info given?? Also what size engine is this, I need to overhaul the motor bearings, rings etc. Any idea where to look for parts first. Thanks for your help.
Loren -- You are located...?
06-18-2002 05:26:56
 Re: 1923 fordson tractor in reply to Dave, 05-28-2002 18:53:20
Curious where you are located. Seems to me that '23 Fordsons wouldn't show up every day and there has recently been one parked by a highway I drive frequently. Just wondering if it might be yours. Are you in NC?
Theman
05-30-2002 08:08:39
The serial number will be stamped in the block casting between the exhaust and intake ports for the #1 cylinder (closest to radiator). This was done by hand at the factory so some of the numbers may be difficult to read. If at some point the original block was replaced there may not be a number stamped on the block at all.
Standard engine size is 4" bore X 5" stroke.
Below is a link to a previous post for parts. For more info, conduct a site search of this board for Fordson parts.
