Dexta clutch problems again (sigh)
8NDexta Ger
06-25-2002 11:54:17
About a year ago, I replaced the (very expensive) clutch on the Dexta. The magic on this live PTO clutch seemed to involve some jig to set up the fingers correctly. Well, a year later and I find the pto clutch doesn't disengage anymore. of course right in time for haying!!!
I tried shortening up the pedal linkage- no different.
i guess I've got to split the tractor again. Does anyone have a procedure or recommendations for setting the clutch up at home without that "factory jig"?
ger
capbuster
07-02-2002 20:47:37
 Re: dexta clutch problems again (sigh) in reply to 8NDexta Ger, 06-25-2002 11:54:17
If it has worked good till this time without slipping I would try to adjust it with the manuals specs first. You can also set both clutches with out this magic tool you talk about, although it makes it easier. Hope this helps, if not, I'm sure Burrhead knows a remedy.
Capbuster
Burrhead
07-07-2002 11:09:36
 Re: Re: dexta clutch problems again (sigh) in reply to capbuster, 07-02-2002 20:47:37
I don't know of any other adjustment CB. Since he already ran it on the installation adjustment and it was okay it sounds like a rivet snapped in the pto clutch and is blocking it.
No external adjustment 8ndextaGer
07-03-2002 09:19:15
I've adjusted the linkage as high as it will go and there is still no PTO clutch action. I'll pull it apart after haying.
