Front loader only works with back arms down?
alex
06-27-2002 12:52:50
Been playing around and the only way I can get the loasder to work is to put the back arms down before I isolate the hydraulics.. Is this right? If so How do i lift the back for extra weight and use the loader.. I bet its some obvious obvious like low fluid or a lever I'm not pulling right:)
thanxs a lot
alex
Getting happier every day:)
Billy Correll
07-14-2002 18:10:09
 Re: front loader only works with back arms down? in reply to alex, 06-27-2002 12:52:50
You may very well have low fluid level. I use my front loader with the rear raised just off the ground. If you raise the rear all the way, there will be too much fluid in the rear lift cylinder and not enough to raise the front lift all the way.
Burrhead
06-28-2002 08:44:14
you're doing it right Alex. Both ends won't work at the same time.
alex
07-03-2002 02:35:49
 Re: Re: front loader only works with back arms down? in reply to Burrhead, 06-28-2002 08:44:14
thanks, but the loader only works with the arms lowered. So how do i raise weight on the back to counteract the loader weight. A back box full of rocks makes it steer better with the loader apperntly but my loader only operates with the back box on the floor :(
I'm gonna check the fluid level I guess..
alex
Nathan
07-11-2002 05:29:41
 Re: Re: Re: front loader only works with back arms down? in reply to alex, 07-03-2002 02:35:49
I have the same problem with my dexta. if the arms are up all the way, I can't lift the loader.
I found if I just lift the arms half way to level out the weight in the back, I then can lift the loader fully. I just thought this was normal.
