Fordson Tractors Discussion Forum
Oil Pressure Problem
Alan D
12-29-2003 13:54:03
I have a '58 dexta recently the oil pressure light has been coming on around 10 min after starting, however we did not turn it off, it seems that the light stays on until the high revs and then it flickers, it also starts to make a backfire sound which is sometimes accompanied by a increase in smoke, tne engine gets warm but not hot, can anyone help????
Tractorfix
12-29-2003 17:29:27
 Re: Oil Pressure Problem in reply to Alan D, 12-29-2003 13:54:03
Take the big round plate off the bottom of the oil pan and make sure the pickup screen is clear. Although it sounds terminal, check the simple stuff first. Make sure the oil is form the 21st century. Make sure an injector isn't flooding the pan with fuel. (the oil will stink like diesel). Unfortunately, it sounds like you need an oil pump or crank job or both.
