446 case points
John
12-20-2002 08:16:20
Does the Onan engine have a distributor with points and condenser or did some have an electronic ignition? Thanks
Jeb Mccranie
12-21-2002 15:31:24
 Re: 446 case points in reply to John, 12-20-2002 08:16:20
The 16 horse onan on my sears has a condensor. It was made about the same time as your tractor
redtractorman
12-20-2002 17:13:34
If you have an older 446 it will have points,the newer onan had electronic,on my 646 with 16 hp onan you can remove the box that the points and condensor are in to change,makes it alot easier.
steveinct
12-20-2002 09:39:13
John, I have a '83 448 with an Onan and points. They did switch to electronic ignitions, not sure when. The points are under the air cleaner housing towards the dashboard side of the engine under a stamped steel cover(1"x3") held down by a screw. Hope this helps! Steve
