1975 210 John Deere
Ron Staples
09-03-2003 20:57:19
im just now getting above tractor ready to pull... if the rules allow, can I place a 12x12 rim on this tractor (stock is 10.5x12) and put the firestone 23floatation lug tire on it and will it fit under the fender????? this may be a real easy question for some, but im just new at this and want the best tire i can accomodate under the rules just drafted here in Maine..(MATC)
ps im willing to shave the lip of the fender if needs be.. thanks for any help
Wally G.
09-14-2003 11:36:16
 Re: 1975 210 John Deere in reply to Ron Staples, 09-03-2003 20:57:19
Don't shave the fenders, just make up aluminum shims to put under the fender (1/2 inch stock works nice) with longer bolts. Change your seat to a lower back style so you can lean back over the seat to transfer weight rearward. If your rules allow it, sharpen the tires and it will pull a lot better on most tracks. Make an adjustable hitch so you can keep your hitch as high as the rules allow.
