317 hydro
joe
12-17-2003 13:34:45
how difficult is it to replace the rear differential and the hydro unit on a jd 317. also when i receive the different unit the hydro and rear end will be split, so is their a gasket between the hydro unit and rearend? thank you.
Bob
12-17-2003 21:37:34
 Re: 317 hydro in reply to joe, 12-17-2003 13:34:45
Gasket is Deere P.N. M44386 ($2.50).
Very simple to re-assemble. One of the long bolts holding the hydro to the rear end housing goes into a hole tapped in the rear case, open on the backside to oil. Use sealant on the threads on that bolt, or you'll have a messy, weepy leak.
