18hp Briggs V Twin II Flywheel
premie farmer
03-27-2004 07:50:08
Can anyone provide the procedure for removal of the this models flywheel. It's never been off and the starter went out and I need to R&R it. I have yet to be able to determine a way to get the nut off the top of the shaft keeps spinning the crank and there's nothing I can see to wedge against the flywheel to allow me to break the nut.
Premie farmer
03-27-2004 13:00:26
 Re: 18hp Briggs V Twin II Flywheel in reply to premie farmer, 03-27-2004 07:50:08
Success! Was able to take a large pipe wrench to hold onto the pully shaft from below and broke the nut lose. Fly wheel came off easily and like I suspected the starter was burned out or at least smells that way.
jimy
03-27-2004 19:06:11
 Re: Re: 18hp Briggs V Twin II Flywheel in reply to Premie farmer, 03-27-2004 13:00:26
Glad to hear it but why all the trouble? You don't need to remove flywheel to remove the starter anyhow.
AIR
03-27-2004 19:59:25
 Re: Re: Re: 18hp Briggs V Twin II Flywheel in reply to jimy, 03-27-2004 19:06:11
Next time zap it with a air fired scoket works great, plus there are other tricks take out plug put a a thing clean rag in the piston with piston at bottom of stroke now turn nut slowly and off it comes
Bob
03-27-2004 09:50:28
Use an impact wrench. If not available, remove spark plug and stuff a length of clothesline rope in the cylinder, leaving a length stick out for removal. The piston will come up against the rope and you'll be able to wrench the flywheel nut loose.
