17h.p. 42 in cut Craftsman electrical problem
Ben
04-18-2004 11:47:20
Does anyone have a electrical schematic for a Craftsman riding mower? I have one that won't turn over, getting 12volts to solenoid through the white wire but not sure if that black wire is a ground that connects right next to the solenoid white wire. Any diagrams or help will be greatly appreciated.
kjm
04-18-2004 20:12:46
 Re: 17h.p. 42 in cut Craftsman electrical problem in reply to Ben, 04-18-2004 11:47:20
Ben, You are right the extra wire is ground. I chased one on a Craftsman last summer.(Made a little money on that one.)KJM
ret
04-18-2004 18:53:34
I had that happen last year, ignition switch was all rusted away. Comes out real easy. REt
MAC,IL
04-18-2004 12:20:33
Ben: type the model number here and see if it shows a schematic.
http://www3.sears.com/
Mike M.
04-18-2004 12:10:11
Don't have wiring schematic for chrftsman,but I do for Murray.You're going to need a PDF to read it(I use adoby 6.0 think you can use version 4 too).
But have you checked 20 amp fuse?or your safty switches?
