3 point hitch attachment for J.D 214
Alf
04-29-2004 21:24:28
Any one know If there is a class 0 3 point hitch for a JD 214. I just bought a used one in good shape. It has a hydralic lift on the deck. Was hoping to Hook a rototiller up for a Class 0 hitch.
Deere Jon 2004
04-30-2004 12:06:03
 Re: 3 point hitch attachment for J.D 214 in reply to Alf, 04-29-2004 21:24:28
G.L. is right about the 3 pt. hitch. The 200 series JD L&G tractors used a Brinly-Hardy Sleeve Hitch for mounted equipment. There are some plans avalible to build an adapter to mount 3 pt. hitch equipment on a sleeve hitch, but you don't have all the ajustability of a 3 pt. hitch. The biggest problem you'd have mounting a tiller to a 214, is driving it. John Deere did make a tiller for the 214, a model #31. there is one for sell on E-bay if you want to look at one.
G. L. Perry
04-30-2004 09:26:45
Think you need 300 or up series to get 3pt. BUT, they did have a "sleeve" hitch I think. It is sorta U-shaped flat stock on edge, that pivots at bottom of the main body in back, tapers out to a pin hole, kinda thick and supportive where a wide flange on attachment slips over and is held on by pin. It's more or less solid, cept to lift up or down. I'm not sure what link goes from hitch to the front controls to lift, soem sort of bar thru body hollows. Make sense?
