318 john deere hydrostaic
Patrick
05-21-2004 10:30:36
I have a 318 john deere hydrostatic drive that dont keep the constant ground speed. the motor speed stays the same. but ground speed varies to the point that I have to keep 1 hand on the the control at all times. The fluid is at the right point. Whats wrong? Patrick
Dave
05-21-2004 21:25:53
 Re: 318 john deere hydrostaic in reply to Patrick, 05-21-2004 10:30:36
Patrick - There are three different linkage setups on the 318, depending on the year of manufacture. Most of them have a beveled washer that keeps tension on the hydraulic control lever. To gain access, remove the right side access panel on the pedestal. Inside, you should see a hex head bolt ontop of the beveled washer. Tighten the bolt, but not too much, otherwise you'll make moving the lever difficult. This is a trial and error adjustment and may take a few tries to get it where you want it. If you have any difficulty, please re-post. - Dave
ken
05-21-2004 16:09:44
lee i think what he is saying and i have the same thing happen on my 430 is if you don't hold the lever it eventually will work it's way back to neutral.my 430 does it the worst goin up the hill in my front yard.otherwise on the flats it takes awhile to do this
lee
05-22-2004 08:06:07
 Re: Re: 318 john deere hydrostaic in reply to ken, 05-21-2004 16:09:44
OK, well, that's a different deal. I thought he was experiencing speed changes with handle in fixed position. This can happen on an incline or downhill if the tractor is a little tired.
lee
05-21-2004 11:48:49
How many hrs? There's a lever under the right rear fender to allow manually pushing the mower. Is it in the correct position?
John
05-21-2004 11:48:43
Patrick, Your shift linkage or the neutral adjustment cam may be worn. If you have a tech manual it will tell you how to adjust or replace. Good luck, John
