212 Mower Deck Diagram for JD ?
Gary
07-07-2004 19:12:49
Does anyone know where I can find a belt diagram for a 212 John Deere Mower Deck online [picture]?
I have the belt off and can't figure out how to put it back ....
(I lost my manual)
Thanks
Gary
gspig
07-08-2004 06:12:53
 Re: 212 Mower Deck Diagram for JD ? in reply to Gary, 07-07-2004 19:12:49
My deck has a diagram one the underside of the deck belt cover. If you still can't get a diagram, post again and I'll try and draw a picture.
JMC
07-07-2004 23:30:30
You can go to www.johndeere.com, then Residential, Parts, then Search the Parts Catalog. Do a model search with the mower deck number (i.e. 38, 39, 47, etc). It will pop up with the number and "rotary mower". Then you can select what index you want to view (sectional will work). Should be a view that includes belts and will give you a pic you can enlarge, find part numbers and so forth. Good luck!
Gary
07-08-2004 08:05:39
 Re: Re: 212 Mower Deck Diagram for JD ? in reply to JMC, 07-07-2004 23:30:30
Hey JMC !! -- it worked .. I got the entire belt diagram!!!! Thanks so much !!!
Gary
Sharlene Lintz
08-27-2006 16:25:52
 Re: Re: Re: 212 Mower Deck Diagram for JD ? in reply to Gary, 07-08-2004 08:05:39
I would like a diagram of the 111 John Deere cutting deck. I'm wondering if the pulley arm is attached to a part or if it is a separate piece. Thank you!
Gary
07-08-2004 07:35:00
Thanks so much for the info ..
Gary
David
07-08-2004 06:12:09
If your are talking about the deck belt, the one inside and under the cover of the deck, check the under side of the cover as many had a decal of the correct installation of this belt. Good Luck
Gary
07-08-2004 10:27:14
 Re: Re: Re: 212 Mower Deck Diagram for JD ? in reply to David, 07-08-2004 06:12:09
... ends up they gave me the wrong belt .. so I am now in business again ...
ged
