17-GTH-L Simplicity Lawn Tractor
D Holden
07-09-2004 12:27:33
I don't have a manual, but I DO have a used tractor that I recently aquired & I need to check the fluids. What is the proper technique to check the hydrostatic oil level for this tractor and what is the recommended frequency to change filter and fluids? Until I locate a manual for the tractor, I want to be sure that I am doing the recommended preventive maintenance measures that this tractor requires.
Thanks again for your help!
Don
Kent
07-10-2004 17:44:24
 Re: 17-GTH-L Simplicity Lawn Tractor in reply to D Holden, 07-09-2004 12:27:33
You can download the manuals for free from the Simplcity site.
You'll need to get the MFR # off the tractors ID plate. It should be 169-something. The serial number will not work...
Don
07-10-2004 21:31:09
 Re: Re: 17-GTH-L Simplicity Lawn Tractor in reply to Kent, 07-10-2004 17:44:24
Kent, I appreciate the information and the link.
I will get it open and check it out to be sure I have the right information!
Don
