318 ignition controller
Tom
07-22-2004 15:17:11
I have a John Deere 318 that needs an ignition controller installed. It looks like this controller is under the rear engine shroud. Not sure though if it's under the flywheel.
Is replacing this controller a big job, and does anyone have any good tips in the replacement of it?
Any info would be helpful.
Thanks.
JT
07-22-2004 15:19:55
 Re: 318 ignition controller in reply to Tom, 07-22-2004 15:17:11
it is under the flywheel, engine removed, f/w removed, there it is. not a bad job, just time consuming.
Tom
07-22-2004 19:20:59
 Re: Re: 318 ignition controller in reply to JT, 07-22-2004 15:19:55
Thanks.
One other question---you said you have to remove the engine---why? For room to get the flywheel off?
Thanks again.
JT
07-23-2004 09:21:05
 Re: Re: Re: 318 ignition controller in reply to Tom, 07-22-2004 19:20:59
to get the blower housing off to be able to get F/W off.
