18 hp Briggs twin motor
Mark in MI
08-03-2004 06:26:23
My briggs twin piston motor lost compression on one cylender. I pulled off the head and found the valve seat was loose and somtimes fallen right out of its place. My question is this. How can I tighten up the valve seat. It wants to slip right out of its place.
Thanks in advance
Mark
JT
08-03-2004 09:47:44
 Re: 18 hp Briggs twin motor in reply to Mark in MI, 08-03-2004 06:26:23
One of two ways, take out the valves, set the seat back in the block and use a center punch peen the block around the seat in three places, 2 o'clock, 6 o'clock and 10 o'clock position. If that tightens the seat enough to stay in, take a flat drift punch and peen the block over the seat to hold it in. If when you peen it in with a center punch in the three places, and the seat will not stay in, then go to a machine shop and see if they can get you an oversize valve seat, if they cannot, then a new short block is the onyl answer. If you go to briggs websight I think you can download a manual, and it also will explain the process with pictures.
Bob
08-03-2004 11:41:22
 Re: 18 hp Briggs twin motor in reply to JT, 08-03-2004 09:47:44
The seat should be reground with a piloted valve seat grinder, after being staked into place.
JT
08-03-2004 13:41:43
 Re: 18 hp Briggs twin motor in reply to Bob, 08-03-2004 11:41:22
OK, ya got me on that one.
