1976 Case Tractor model 444
Rick Alden
09-18-2004 18:40:51
I have had the motor taken out and completely rebuilt for my tractor. The tractor ran ok before taking the motor out and , when they put the motor back in, now the motor runs real good, but when put in gear foward or reverse, it just surges kind of go and stop, this is a hydraulic transmission, tranny was ok before taking motor out, can any one help
Gary Duff
09-19-2004 16:47:25
 Re: 1976 Case Tractor model 444 in reply to Rick Alden, 09-18-2004 18:40:51
Make sure you have the right oil for the hydraulic system.It take 20W50 motor oil not hydraulic oil.Hydraulic oil is to thin and the pump cavites making the drive surge.If you have the right fluid and its up to the right level it should work.If its an older style tractor with the resevoir in the front,there is a screen inside that is supposed to divide the tank and this screen comes loose and falls down and cover the outlet restricting the flow of fluid,take a wire and fish inside the tank and pull it up to the fill hole atke a hold of it with needle nose pliers and wiggle it out.
