318 JD W/onon 18hp
Tom Lum
10-05-2004 14:13:03
My onan 18 has a oil leak on right side of engine. Thought is was filter , but wasn't. If anyone might know where it could be coming from, I would appreciate the help.
Kevin Clemons
10-07-2004 07:34:37
 Re: 318 JD W/onon 18hp in reply to Tom Lum, 10-05-2004 14:13:03
I've experienced oil leakage at both places, the oil sending unit and the oil filer base. (B43E engine - you didn't say whether or not it was the B43 or the P series). If you find out that it is the gasket , not the sending unit, make sure to follow the instructions in the technical manual when replacing the gasket for the oil filter base. You MUST use thread sealant on the top cap screw. This tapping passes completely through the casting. I use non-hardening sealant, like permatex #2.
EdB
10-06-2004 02:24:14
My 318 did the same thing. The oil filter screws onto an adapter that is bolted to the block and the gasket between the adapter and block was leaking - slinging oil all over the place. Cant remember how the adapter was bolted on, it has been awhile and have since retired the 318.
Mazz
10-05-2004 20:52:36
Tom - crazylunker hit on one of the most common oil leak issues on the Onan engines. If that is indeed the sorce of the leak, when replacing the sending unit, take care not to overtighten the new one. Many times, people overtighten the replacement, and crack the internal seal in the unit. - Dave
crazylunker
10-05-2004 18:18:39
becha it's the oil pressure sending unit
pdi man
10-05-2004 17:08:13
i think there is a gasket behind the filter mount. replace that.
Tom Lum
10-06-2004 05:23:52
 Re: 318 JD W/onon 18hp in reply to pdi man, 10-05-2004 17:08:13
Thanks alot for the quick response and info.
