1978 IHC 1450 garden tractor
Bill Hendricks
11-30-2004 09:01:15
I have rebuilt this engine 3 times thought it was time to consider replacement or retrofit with a differant engine has anyone changed motors. And if so which one?
R Bedell
11-30-2004 10:12:36
 Re: 1978 IHC 1450 garden tractor in reply to Bill Hendricks, 11-30-2004 09:01:15
The Kohler K321AQS is what is suppose to be there.
I suppose if you changed the motor mounts, you could put a KT-17 or a M-18 in there also. Don't know if the panels would be an issue. Then you might have drive shaft compatibility issues also.
JT
11-30-2004 10:34:48
 Re: 1978 IHC 1450 garden tractor in reply to R Bedell, 11-30-2004 10:12:36
I would consider having a sleeve put in it. A new engine should be K321AQS-60312, I think, they are around $1600.00 new. It can ve rebuild with a sleeve and new piston for a lot less than that.
Kent of SW MO
12-01-2004 06:33:13
 Re: 1978 IHC 1450 garden tractor in reply to JT, 11-30-2004 10:34:48
From what I have heard the K-series engine is no longer available from Kohler. The L-head design is emission dirty.
Kent
JT
12-01-2004 07:51:55
 Re: 1978 IHC 1450 garden tractor in reply to Kent of SW MO, 12-01-2004 06:33:13
I checked with my supplier yesterday and this one is still available at this time. The way they are getting this done is: your gonna love this one:
The EPA has given permission for a certain amount of time for Kohler to sontinue selling the K series engine. here is the catch, for every engine that Kohler puts into the field, one has to be taken out. ie, if YOU replace YOUR engine in YOUR Cub Cadet, by law, you must destroy YOUR engine and make it unserviceable, But, Kent you are right, they are slowly getting them to be NLA, and if it still available, the price on these engines are way out of line in price. A good example, 3 years ago a KT17 for 782 Cub or 317 for Deere sold for $1300.00, noe they are over $2200.00. that is why they are starting to make Command engines to fit where these used to go.
Jim
ANON
12-01-2004 16:22:06
 Re: 1978 IHC 1450 garden tractor in reply to JT, 12-01-2004 07:51:55
Leave it to the government and the EPA to screw up a good thing!!!!!
