1976 Cub Cadet Electric PTO
John J. Wach
12-12-2004 04:49:16
Can someone tell me if an electric pto will engage with the power on but the tractor not running? I am getting 12 volts to the pto coil. I am trying to determine if the pto works. Thanks
John J. Wach
12-12-2004 15:06:05
 Re: 1976 Cub Cadet Electric PTO in reply to John J. Wach, 12-12-2004 04:49:16
Thanks to everyone for their advice and help. After removing the PTO and jumping it directly off the battery I have come to the conclusion that it does in deed work. I have since re-installed it and I can see, hear, and feel it working. The true test will be when I get my snowthrower attached. There does not seem to be a whole lot of adjustment. I need to purchase a manual. Does anyone have one for a 1000? Thanks again.
R Bedell
12-13-2004 02:55:43
 Re: 1976 Cub Cadet Electric PTO in reply to John J. Wach, 12-12-2004 15:06:05
Manuals are availabe from your local CC Dealer, CC's web site, most Case-IH Dealers, and several online Dealers to include Binder's Books.
Bob
12-12-2004 12:04:00
If you actually have 12 Volts at the clutch coil, whether through the tractor's electrical system, or a jumper wire, it should make a distinct "click", and the pulley should be locked to the engine, so if you turn the pulley by hand, the engine will turn along.
For safety, remove and ground spark plug wire(s), so there's no chance of the engine firing while you're messing with the clutch.
R Bedell
12-12-2004 11:22:01
In 1976, Cub Cadet was producing their "Quietline" series. The wiring on the QL's was so that you could NOT start the cub with the PTO in the "on" position. However, with the motor off, and the PTO "on" you could here it engage (or click).
lucass
12-12-2004 10:17:43
im pretty sure the pto will engage with the engine off,key on . you can hear the click on the pto when you try it.
