318 john deere smokes when hits bump
j.d.forever
12-26-2004 07:54:00
My 318 smokes bad when I hit a bump . It uses over a pint of oil in about 1 hour.It runs fine with lots of power . I did notice oil film in the air cleaner.I replaced the air filer thinking it may be pluged it did not help. Any help would be great. Thanks Dale
jd 318 help
01-05-2005 16:42:04
 Re: 318 john deere smokes when hits bump in reply to j.d.forever, 12-26-2004 07:54:00
Did you get it fixed?
DALE BERRETH
01-05-2005 18:29:42
 Re: 318 john deere smokes when hits bump in reply to jd 318 help, 01-05-2005 16:42:04
no not yet
jd 318 help
12-27-2004 21:18:40
Sounds like either you have an oil control ring gone amuck, or your crankcase breather is bad.
Here is a simple test.
1. Remove the dipstick.
2. Breathe into the dipstick tube - you should be able to breath fairly easily.
3. Now inhale - you shouldn't be able to inhale. If you can, your breather is bad.
Terry B
12-27-2004 19:14:21
Check and make sure you don't have one of your spark plugs fouled. These engine will run fairly well on just one cylinder. The problem is, if a plug is fouled, the governor opens the throttle plate putting more gas into the combustion chambers. The gasoline washes by the piston rings on the dead cylinder diluting the oil and causing oil carry over through the breather. If you are using a pint an hour this would figure out to about an 8 to 1 gas to oil mix which would give constant exhaust smoke as even the real od two strokes ran 16 to 1.
Chad
12-26-2004 08:53:06
You might check the breather. Usually has a tube that goes to the air cleaner. If not workin correctly it will allow oil to get to air filter
