1966 JD 110
gregPA
01-17-2005 09:18:37
hello all. i'm new to the JD's. i picked up a fixer upper a few weeks ago. it was minus muffler, gas tank, grill and seat. i made a muffler got a grill and seat and bought a used gas tank. i have the service manual but other than gallons it gives no dimensions for the tank. the fellow i got it from says it's the right tank. it fits in the cradle fine but sits tight against the inside of the hood, i'm thinking it might rub through the hood after awhile. is there supposed to be clearance between the ends of the tank and the hood? is this the wrong tank maybe? also one more question. when i start the tractor the gen light stays on. i'm not too much on charging systems. when i increase the engine speed the light gets brighter. i'm guessing that it is charging but something could be wrong with the regulator. am i headed in the right direction? thanks, greg
Jogg
01-17-2005 12:37:01
 Re: 1966 JD 110 in reply to gregPA, 01-17-2005 09:18:37
If you're new to JD L&Gs, also have a look at the website below
gregPA
01-17-2005 13:30:56
 Re: 1966 JD 110 in reply to Jogg, 01-17-2005 12:37:01
thanks, it looks like a lot of info there as well as here. greg
Bob
01-17-2005 09:25:38
It's NORMAL for the tank to be a CLOSE fit (read TOUCH) the insides of the hood.
Bob
01-17-2005 09:48:29
 Re: 1966 JD 110 in reply to Bob, 01-17-2005 09:25:38
P. S.
I think you"re on the right track suspecting the regulator.
First, verify that it has a good ground. Most likely it has rubber mounts, and there is a ground lead to "jumper" around the rubber mounts. Verify the lead is present and unbroken.
gregPA
01-17-2005 11:28:24
 Re: 1966 JD 110 in reply to Bob, 01-17-2005 09:48:29
thanks Bob, i'll check the reg. ground this week.
